40IDA Hesitation/Stutter Between 3-4000RPM
Hey Gang,
During Parade last month they had quite a bit of time to get acquainted with my carburetors. After some around town drives and a few short trips I plunged headlong into the road trip from Salt Lake to Monterey.
As with any new motor you're always anxious and listening for anything that may be wrong. As I got out on the open road immediately began to notice a hesitation between 3000 and 4000 RPM. Originally I thought CDI boxes but I quickly realized it was a carburetor issue.
The first leg of the trip was Lake Tahoe so the high-altitude settings were pretty safe and standard. Once I got down to sea level the following day I noticed my hesitation and stutter was still there between 3000 and 4000 RPM. It was especially annoying because highway speeds were right in that RPM range.
I did a little bit of reading (on Paul's wonderful site) and the only thing I can think of is the progression air correction jets. Another knowledgeable friend suggested that I might need the taller secondaries.
Does anyone have any similar experience with this type of an issue with the 40IDA3C?
The motor is a 2.5 L twin plug. It has smaller 38 mm intake ports and I live at 4500 feet so the 40s actually work well with this motor. It has the Web 102/140 mod 906 cams.
Thanks in advance. Looking for suggestions from anyone who's BTDT. ;)
