5 Attachment(s)
FS: @eBay --- '73 'S' Targa . . .
VIN = 9113310830
Eng# = 6331898
Trans# =
'. . . Original owner car . . .
. . . I drove this May production car off the dealer lot in August of 1973. Matching numbers. Original window sticker, dealer invoice, and very complete service records. No rust. It has been meticulously maintained over the years, and continues to run like new at 143,000 mi. Originally metallic silver, it was repainted GP White in the mid eighties. Completely disassembled for paint . . .
. . . At the same time the following modifications were done:
..Engine was opened to 2.7 using original RS 8.5 compression Mahle Nikasil Pistons and Cylinders on the original matching number block. Shuffle pinned, case savers, line bored, upgraded oil pump, 930 tensioners etc.
..MFI injection pump converted to RS Spec by Gus at Pacific Injection
..RS rear factory steel flares were butt welded and leaded in, hand shaped rear steel bumpers to flares. No Bondo
..RS original factory ducktail and aftermarket front fiberglass spoiler
..Fuch 6x16 and 7x16 wheels with Bridgestone RE11’s
..Engine had thorough top end and complete reseal at 103,000 miles and runs strong
..Leakdown at recent last completed service was 98% on all cylinders
..28 tube factory brass cooler runs through original 73 thermostat
..Dealer installed A/C , new Sanden type compressor. Works great
..SSI heat exchangers
..New alternator
..Recaro LS sport seats done in perforated leather by Tony at Autobahn Interiors
..European H4 headlights, 80/100W with relays
..Factory sport shift
..Factory one piece replacement dash
..Targa top completely rebuilt by Dan Pechtel
..Full suspension rebuild at 131K, Elephant rubber bushings front and rear
..Shocks: Koni Gas adjustable, red front, sport yellow rear . . .
. . . Included: Original steering wheel, warm air intake box, 2 6x15 and 2 7x15 Fuchs . . .
. . . I use the car about 3-5k miles a year and she is a very reliable strong runner with no issues. She is kept to a very high standard you should have no qualms about picking this car up and driving her cross country. All you’ll need to do is regular maintenance . . .'
http://www.ebay.com/itm/141419123045...045%26_rdc%3D1
(Not mine)
