I have a 1973 911 with the 2 battery original setup.
I want to put a trickle charger on the car. Does it matter
which battery I connect to. It seems that I read somewhere
that it does? Thanks
Hope this will help Mike:
http://www.early911sregistry.org/for...attery+charger
Cheers
Both batteries wired in parallel in car, thus it doesn't matter what battery the charger connects to. Confirm all battery posts are clean. Don't overcharge, possible even with a trickle charger. For long term battery storage, use a battery maintainer.
Sherwood
Battery tenders for our Porsches work great but can fail. A ground disconnect will serve the same purpose on the drivers side battery. The passenger battery was put there
by Porsche only to balance the stability of the car. Now,with the advent of batteries weighing in under 10lbs, disconnecting and removing passenger battery and replacing the
drivers side battery will save close to 60 LBS, or the equivalent of about 9 gallons of gasoline or making a 200lb male weigh 135lbs.....just sayin'
My experience is they work ok , you just need to get it hot.
I'll actually drive mine in very cold temperatures as long as there's no salt on the ground.
