Originally Posted by
gumby1953
If you have the correct VIN then its ezzie!
This is what I normally do (but not always):
First you add the numbers 911 to the end of the vin #, then multiply the first 5 numbers x 7, then use that total and eliminate the 3rd and 6th number and divide that total by 1.8999. The number that you get should be somewhere in the range of infinite calculations, to hopefully (in a chance of 1 billion to 1) be the number your looking for!
Good luck...... this calculation has really never worked for me but I was told it might someday!
KJ
