3 Attachment(s)
Need help identifying cams
Can anyone help to identify these cams?
The numbers stamped into the castings are:
???.105.103.??
???.105.104.??
My guess is they were 901.105.103 and 104.01. That would put them most likely from a 1965 911?
Engraved in the cams is "WEB 134 149"
My guess is they are the Web Cam RSR Sprint grind.
Each one of the cam lobes and main bearings has an oil passage. Each one of the main bearings has an oil groove machined in it. I have never seen the grooves in a cam before.
They are 47-mm, 3-bearing cams.
How can you tell if the cam was made to go with MFI? Does the LH end have 4-bolt holes?
My best guess is these are 1965 cams reground to RSR Sprint specs.
Thanks in advance,
Rob
