Will Weber carbs fit on the same manifolds as Zeniths?
Tough question?
What port sizes are your cylinder heads?
I'm not sure, it's a '69 911E engine with Zeniths, and I'd like to fit Webers.
Obviously a 1969 911E should be fitted with an MFI system and the inlet ports would be 32mm diameter.
I think that all of the Zenith inlet manifolds were made to suit a 32mm inlet port so they should fit without problem.
The carb side always suits a 40mm diameter barrel and both Weber and Zenith should bolt up without issue.
Thank you.
Yes, I wish the engine was still wearing it's MFI, but I have to work with what I have.
