Headliners
I am aware that 'diamond' pattern headliners are available but I a keen to find out if the original 1966 pattern with a square hole pattern are also being made.
The 'normal' aftermarket headliners use a square pattern but I believe the spacing is different to the early headliners which use a finer 'pitch' of holes.
I am not sure when the pattern changed to the diamond but suspect it may be around 1969.
I need a number of correct pattern headliners and don't want to have make the vinyl as the smallest quantity would be 300 metres.
