Need a 2.7 crankshaft & 2.2/2.4 cylinder barrels(84mm) for engine I'm having built.
Prefer Biral, but consider cast iron. Don't have to be perfect since they will be bored slightly.
I can supply the crank and cast cylinders. PM me for details.
My engine builder just said I should go with alloy cylinders.
I still need a set.
I will check my stock to see if I have a set of 84mm birals
