1 Attachment(s)
FS: new parts - one lot
selling as 1 lot all brand new $650usd plus shipping
ALL NEW PARTS 1 LOT
91142359301 Accelerator Rod Boot, 911/912/930/912E (65-89)
91442392202 Clutch Cable Boot, 911/930/914/912E (70-77)
91434771300 Steering Wheel Bearing Spring, (60-73)
91442422400 Shift Linkage Friction Ring, 911/912/914/930
90134775300 Steering Shaft Shear Bolt (65-94)
Fuel Cap, 911/912 (68-75)
91442321100 Bell Crank Bushing, (50-89)x2
91120114100 fuel filter
91161815400 dme relay
90133229312 - cv boots x 4
91110723300 oil line x1
90110734800 oil line
90110734701 oil line
91160293300 dist. cap
91134732204 rod end x2
sm42340190 Pedal Bushing Kit, Bronze (65-86)
Stainless Steel Brake Hose Kit, 911/912/930/914/912E (69-83)
smc 000055 Steering Wheel Restore Kit (60-73)
91110570001 Steering Shaft Sleeve, 911/912/930/914/928
91142429400 Shift Coupler Boot
Throttle Ball Socket, RH Threaded, 356's/911/912 (50-77) x 2
90174129100 Speedometer Cable Boot, 911/912/914 (65-71)
100912181 chain gasket set
90150493220 fuel tank seal
90120127720 fuel filler flap
Oil Sump Plate, 911/930 (65-83)
91142479203 heater vent plastic handles x 2
69542422300 shift coupler bushing
91142413900 gear shift socket
