I need a pair of the Early 4 bolt 2 pin shaft flanges with the fine splines. Let me know what you have please.
Those are hard to find. Depending on the diff you are using you can change the internals and use course spline stubs which are quite common.
LSR911
I can't remember any 4 bolt, 2 dowel, fine spline drive flanges. Fine spline was either 100mm flange with 6/8mm bolts or 110mm flange 6/10mm bolts. 911 or 914 drive flange with 4 bolt 2 dowel were coarse spline.
Explain your application, year model and parts purchased, we all probably have a solution for you.
