6 Attachment(s)
FS: 911 914 TRAILER Custom made , AS NEW, for low clearance rear engine cars, EZ load
Used 10 times for local Concours events. . Custom special construction for low clearance cars. 17'4" overall length so it can fit in a standard 20 ft garage with the
car on it. Lightweight structural steel tube construction. EST weight is 1600 pounds.
Double 3500 lb dropped axles w/ electric brakes. Axles are set back to accommodate tongue weight balance for rear engine vehicle. Deck tire rails are 13 foot long and 16 in wide. Outside of tire rails are 5'11 1/2 " and inside to inside is 39". 2 5/16 ball hitch.
Rails were built with a gradual 2 inch arch slopping in the rear , rather than a sharp dovetail, which allows for loading without high centering the cars chassis, has 5 ft load ramps and 2 spare wheels. Manual winch and tie down points at all 4 corners. Tie downs as pictured [for a 914] are included. Front wind / rock shield is alum diamond plate which easily unbolts or swivel down as needed. Steel Diamond plate side decks with flush lighting, Fenders are lined. Tires are good to go with aluminum rims. Swivel wheeled tongue jack . Standard 7 pin trailer electrical connector with brake aux battery.
Center section has indoor / outdoor boat carpet over plywood. Painted in charcoal metallic gray. Perfect condition throughout. California title and registration.
Never left outside overnight / stored indoors always. $4750 in San Diego.
