Engine hesitates and backfires after driving an hour-
My new MFI system seems to be working really well.
I had Marty at H&R rebuild the pump and I installed 6 brand new injectors.
The fuel console is cleaned-up and it has a new filter. The primer cold start solenoid is removed and plugged. Its wiring at the engine is new but it's pigtail for the solenoid is taped off at the filter console.
In the colder weather I had no problems. Now that we are seeing 90 degrees and more my 1969 911S will begin to hesitate after running an hour.
Since the car idles perfectly and there is no issues seen on the Tachometer I'm betting it is fuel related.
The fuel pump is very old and I wanted to see if there were any easy ways to troubleshoot this issue-
Since the car has to be at oil temp 100C and that temperature is only reached after 20 or more miles it is difficult to duplicate the conditions in my garage.
I checked the pressure by-pass banjo fitting with a pressure gauge when I first installed the MFI and it was stuck but I was able to free it up. It could be bad again. The car runs great for the first 40-50 minutes...
Is the phenolic bypass element something that would be influenced by under hood temps after running an hour?
Or would the fuel pump itself be the likely offender?
It is the same pump that was on the car when I got it and was running Webers with a pressure regulator in 1999...
What would be a good sequence to root out this intermittent problem?
Gene
