Looking for this pull rod for a 1971 - 245mm in length. Thanks
Nobody have one ?
OK, so still looking...thought I would add photos to clarify what I am looking for...I am looking for the rod that connects to the bracket circled in blue. There are two sizes, I am looking for the 245mm one (measured without the end pieces)
Attachment 518001
Attachment 518002
Hello
I have a rod with Ball ends at both ends.
6 5/8 shortest 7 1/4 full length with ball ends on.
Don't have MM tool so you need to see if that works for you.
George
Worst case scenario just make one, 5 mm rod Alfa dealers sell the ends as well as Partsklassic ( actually good price for 4 from them ) then a couple of 5mm nuts and a 5mm dye to cut the threads I make linkage bits all the time this way
Thanks, Rick
