Anyone know a source for the 18 watt bulb. I have 2 new fog light lamps and neither have bulbs.
900.631.123.90 Linolite lamp (bulb) Qty: 1 SS: 900.631.123.92 PCNA 2021: $5.88
Overall length = 42.50mm This is a critical dimension. Vendors use different locations to measure length.
Glass Diameter = 14.5mm, so Globe: T4.63
Metal Ends Diameter = 8.5mm, so Base SV8.5-8
Attachment 547839
Common description: Festoon bulb, 15×41mm
Osram K15608, 12V-18W, Clear Festoon Bulb
Hella K1218 = Hella 8GM 002 091-121 = Hella Festoon Bulb, 12V, SV8.5-8 T4.6
Bosch 1 987 302 229
