1 Attachment(s)
Need a couple of dimensions to fab a tow bar
I'm going to flat tow my soon to be re-acquired 67 911S and I need a couple of dimensions so I may fabricate a tow bar. Picture shows what I am going to retreive.
What I need are:
- The distance between the front torsion bar tubes, this is a center to center distance. It can be taken as the distance between the front bolts on the cover caps or a distance between the tubes plus the diameter of the tubes.
- I also need a good diameter dimension of the tube itself. This would be an outside diameter.
By the way, I have towed using this approach in the past and I am comfortable with it.
Thanks!
