Looking at an ad for EBS... for Nickasil plated cylinders..
I have a few Mercury offshore race motors with Nic cylinders (2.5L outboard)... So I assume you use Titanium Nitride coated rings too?
The cooling is different from the steel bore to the aluminum coated cylinders. Is this the same with air cooled?
I think the weight saving is around 15 pounds over steel. Is that about the same?
