Guys
Mine had rusted away but need the clip for the vapor canister .
Right hand corner of the photo
Guess needs to be cut from parts car .
Let me know if you have this
Attachment 560678
Guys
Attachment 560678
I bought some steel rod 4.5mm and spent 2-3 hours shaping .
When I got both sides to the proper bend the last push/hammer spot/fractured the steel.
This happened twice …
Also thought this was the high carbon steel which is suppose to bend ?
Happy to have someone give it a try and I will purchase
Guess this should be in the WTB posts
hmmmmmmmmmmm.... the factory weld looks like a big wad of bazooka bubble gum ...
cant you incorporate the welding of the part to the car with the welding of the crack?
What’s a material to bend .
Good thought on using broken pieces
Hope you find what you need over here
Since it’s going to be painted anyway why don’t you just use a 4.5mm brass rod? Easily bent and should be strong enough to keep the vapor canister in place.
Alan
N.J.
Like that solution, will get at it tomorrow and advise how things work
