@all
i do need the early hot air tubes
000 043 205 15
diameter 24,5
#42 in the parts diagram.
the previous caretaker had these cut&shortened on both sides?!!
@all
000 043 205 15
diameter 24,5
unfortunatly I havent found this size as a brown coloured Papproh yet.
You might use this:
https://www.amazon.de/KLIMAFLEX-SCHL.../dp/B0743FFGTV
@all
I could source some NOS hot air tubes/hoses in a slight gray brownish color…
brown inside..
25m are with me now…
assuming this color is better fitting than that only available black..
but have a look
