4 Attachment(s)
FS: 1972 ST Tribute project
Just in case this ad is not understood it is almost a complete car.
all trim is bright and new,Gauges are rebuilt
all wiring is in the car all fuel line and brake lines are also in the car.
Here is a list of more parts that come with this ST Project
I have many pictures and will send them after we talk.
H 1 headlights
L & R turn light housing
L & R new silver trim lens
L & R grills
Fiberglass front bumper flared to match ST flares
new front bumper mounts
gas door welded body work done
all trim done in bright coating
Door frames
1/4 window frames
1/4 lower trim
door top trim
Original silver engine gril
lL & R rear light housings
L & R silver trim lenes new
original clips and screws to mount tail light housings
License plate lights and wire harness
Factory rear bumpers flared to match ST flare
steel center panel
new aluminum bumper guards
rear upper and lower deck lid latches
trunk upper and lower latches
Complete air blower with vents trunk
vent control slide dash levers and cables
all gauges rebuilt with silver dot look
Very good used dash pad
door seal and carpet strips aluminum
L & R regulators
all tinted glass NO windshield
No front and rear windshield trim with buy new
L & R knee pads dash
ash tray
clam shell steering whee
lRS Door panels with pockets and handles
outside door handles
aluminum cross beam
new RSR coil over Bilsteins shocks 19 MM raze
new rear coil over Bilsteins
F & R sway bars
SC spring plates
NEW 1972 hard oil lines from tank to front oil cooler
28 tube oil cooler
964 oil tank mounted with outside cap
side fill oil cap hole welded and body work done
oil filter mount 1972 only
oil thermostat 1972 only with oil lines most fittings for oil cooler system 1972 only
1988 aluminum rear control arms complete
fuel pump for 3.8 engine
jump seats if wanted
L & R 1/4 panel interior parts
rear axles
915 shift tower
915 shift rod and couple
peddles
e brake handle
shift coupler cover
915 trans with side oil cooler
8 X 15 fuch's finished
9 X 15 fuch's will be done as soon as Harvey can do them
There are many more things just need to ad to list
What is needed to complete build is final block sanding and out side paint
front windshield and trim for both front and back glass
carpet, head liner and some vinyl recovered
I have a 1972 ST project and want to sell as is.
PLEASE READ ABOUT THIS CAR
Rust free 1972 clean title in Ca
Factory dash pad used but very nice
3.8 engine complete with all the parts to make it run
915 5 speed with outside oil cooler
Razed RSR Bistrein coil over shocks
964 oil tank
NEW hard oil lines to front oil cooler
8 & 9 X 15 fuchs
Many more new or rebuilt parts.
Send email and I will send my phone number so we can talk.
I can't spend time typing all the different ways to buy this car.
Many options. I will take some pictures tomorrow of the ST now.
$130,000.00
The first picture is what it looks like now
3.8 engine is out of OTTO'S race 914 /6 and has very good leak down video's i can sent after we talk
Last picture is not my car but what I going to have it look like
