MFI Microswitch - Linkage Interference
While adjusting the MFI throttle linkage system end-to-end on my ‘72E for full opening at the butterflies, I discovered that at 90% opening, the actuating lever on LH side (in the microswitch vicinity) comes in contact with the rear wire terminal of the microswitch, stops bout ¼” short of full stroke, and tends to bend the rear wire/terminal junction of the microswitch. The microswitch, bracket, and wiring harness of my car are all original and never been tampered with.
Regardless, I removed the microswitch and rotated the L-shaped rear tegminal 180 degrees (it is attached with a tiny screw) and reinstalled it. This rotation moved the terminal inward by about 3/16”, enough for the linkage to clear the rear terminal/wire and move freely.
Please note that the linkage for '72-'73 cars is different on the earlier MFI cars, and my observation may not apply to the earlier MFIs.
