Adding a second fuel filter?
I have a 1966 911 with an inline fuel filter between a Bendix pump and Solex carbs. The pump continues to get a significant amount of particles from the fuel tank. It's a mess. I plan on removing the tank and cleaning that unit. Until I action tank removal project I'm considering adding a second filter to protect the pump from build up. Please suggest a location for this bandaid. I was told a filter is located somewhere near the tank itself. Is that true? If so, are replacement filters available? THANK YOU.
