Just wanted to confirm the torque for the flange nut on the Bilstein insert into Boge. Recommend is 98 lbs? And the top nut inside the front trunk is 58? I have the special tool. Thanks.
Also - the torque for the ball joint to A arm is 180?
OK, so now that all you guys are back from Rennsport 7.... Can someone confirm for me?
