Looking for 12 karro 8g bolts for my 1965 911 restoration project.
Bolts have 14mm head. 8mm thread.
Any help is greatly appreciated.
Looks like these are M8X15. I likely have a set. PM me with your email for details.
These should be fine thread, not your usual M8 thread.
i do have 2 karro 8G and 6 kamax 8G head size 14mm 8x15 fine thread that came off of the hinges of the same car..don`t know the vin since i only had the cut out a-pillars(with the monkey motion holes in the pillar same vehicle as this panel came off
https://www.early911sregistry.org/fo...48#post1164448
last foto is for thread comparison
karro "normal thread"sw14 8mm bolts can be found on early cars brake dust covers as well just in case you want to go for M8 by replacing the threaded plate inside the a-pillar---but they need to be extended by a few mm....sounds crazy but can be done
2nd to last foto would show the 3 different 14mm brands i`v found on early cars during the years--if i only would have placed one karro instead of 2 kamax on the table when i did the fotos
