Need your expertise muchachos,
My '73 has the stock wiring setup for the thru-the-grills. What method to you suggest to by-pass the relay so they can be turned on independent of the headlights other than completely rewiring the switch? Wire colors and fuse numbers appreciated.
Gracias,
