Tech questions lean/rich mixture
Hello,
First I'll describe my engine then I will list a few questions.
Car is a '69 T non sunroof coupe, 205 16s, a 2.4 case 2.7 RSR pistons and cylinders, S heads, squirters, S cams, Webers and factory heat exchangers with a Sport muffler. tall ring and pinion I think 7:31
and short gears in the trans. The cars does 0-60mph in 5 seconds flat even though I granny shift second. [ is there any other way with a 901 box ] The motor was professionally built for me in 1974. The motor has only 20K on it.
My questions:
Is there any other way to determine to see if the engine is running rich or lean other than checking the spark plugs.
What problems will occur by running the engine too lean or rich.
I read on another forum that it is best to lean your carbs when running megaphones.
If exhaust cross over pipes are so important why weren't they used on the 908's, 910's or 917's. Or why doesn't Ferrari use them on thier present F1 race car.
Megaphones, Why the different lengths for 2.0, 2.2 and 2.7, 3.0 engines.
What is the purpose for a megaphone to taper out to a wider opening at the exit end.
Any help is greatly appreciated.
