Weber 40 IDA jetting
Hello,
My 2.2 T from 1970 does not have classical Zeniths but a pair of Weber 40 IDA.
I am going to clean/rebuild them, but as they are not standard on my engine (I suppose they come from a 2.0 engine) I have a doubt about the jets...
Can you suggest me the good jets/venturi for street use on a 2.2 T engine ?
Weber Set Up
I have had good luck with the following setup. This should work well for a 2.2T or 2.4T
Chokes 30
Main jets 130
Air 170
Idle 55, you may also try 60's if transition is not smooth
Emulsion tubes F-26
Bobby Smith
My 2.2 with E P/C's are and early 67 cams are set
Venturis -30
Main jets - changed them from 125 to 130
Air bleeds - 180
Idle jets - 55
Idle air bleeds - 110
Car was running PERFECT (thanks Matt at Eurometrics) before the ice age set in
Thanks to every body.
I have a big doubt, may be my venturis are 27mm, from a 2.0 T ... I will check this Week-end.
Zaza,
Stock venturis are 27mm on a T. If you want 30s btw, I have a set.
Sherwood
