I'm right in the middle of having the suspension reassembled on my '69S. We were going to go from the stock 23mm rear torsion bars up to 25mm. My mechanic sourced a set of used 25s but ran into a fit problem. If I understood him correctly he thinks the 25s are the same size (diameter) spline at either end but that the 23s out of my car are thicker at the outer end and thinner at the inner end. Does this sound accurate? I spoke with Al at Parts Heaven. He seems convinced that all rear torsion bars should be the same fit from '65 to '86. I'd hate to order a set from him and have my mechanic say I told you so.
Can anyone clarify this for me?
Thank you.
P.S. Here's hoping this is the last hurdle before I get this thing back on the road.
