Restoring MapDoor Pockets
Does anyone know how to remove the map and door pockets? I have looked and looked and it is not intuitive. It seems that the screws for the door pockets are [I]inside[I] the pocket and unreachable. Deduction says that if you remove the map pocket, the door pocket will hinge down far enough to get at the hinge screws. But how do you remove the map pocket? I could not figure that one out.
Has anyone restored the map pockets by repairing a speaker hole? Help in this area would be most appreciated. Thanks.
Scott
