How do I remove the alu dashtrim with the basket weave inserts? Are they just glued on and must be carefully pryed off? I have to remove the middle part to get the old 8-track player out of the dash.
Car is 71T
thanks
Car is 71T
thanks
John-
It's held on by foam double sided tape. Break the bond with a putty knife. Hardware stores sell similar tape for reassembly.
-Scott
See if you can locate a 3M double sided tape as the general harware store tape "dies" in the heat fairly quickly
There are several nuts (8mm?) that secure the plates to the bulkhead. Undo them and your home free. Don't pry or I'll have to sell you my extras. HaigQuote:
Originally Posted by Zithlord
Nuts? Not on any of the trim on my '70E.
-Scott
Scott, I'm the one nuts. I was thinking on the lower upholstered pieces. Been spending the past few years working on 356's not 911"s. Sorry for the misinformation. Still be careful prying off. HaigQuote:
Originally Posted by Scott Clarke
Scott, I'm the one nuts. I was thinking of the lower upholstered pieces. Been spending the past few years working on 356's not 911"s. Sorry for the misinformation. Still be careful prying off. HaigQuote:
Thanks you guys!
