I am searching for the right Bosch inditification numbers for the distributor for 2.7RS with MFI and 019 injection pump ,who can help ?
Struggling with a gap between 2800 RPM and 3200 RPM .Motor is rebuild and we changed the pump because we thought the failure was there but nothing changed .
Timing is oke , new spark plugs mounted compression checked etc
The only thing left is to test the injection plugs but I am not very positive if this can be the problem.
Is there someone who has a good sugestion ore had same problems ?
I would be very nice to solve this at the end.
