Did they all come with the switch installed? My car has the switch, but no lights.
Check to see if you have wiring and brackets under the grills.
They only came with the switch IF foglights were installed.
If the car came with factory fog lights the factory wiring will be in place look for that and the relay. The relay will have a white/yellow stripe, white/green stripe, red, and blue/white stripe (color from memory, I think Iam right) coming out of the relay. Follow the plastic wire sleeve to see the wires that come out. FYI the relay will be down by the fuse panel. One relay will always be in place if you see more than one than it could be the factory relay for fog lights.
