Window Issue
Hi All,
I have noticed the lefthand drivers side window is really stiff, seems to only going down about 2 inches. So i proceeded to pull off the door trim, my question is there a trick to getting the front pocket off ?
I got the door handle off and now a little stumped as to how the front pocket comes off......suggestions please.
Thanks in advance for all the help
Clayton
access to the nuts for the front pocket is thru the opening behind rear pocket.
you need to release the bungee, let the rear pocket drop and insert your hand in opening in door where you can reach behind front pocket where (2)10mm nuts are at the top of the pocket ends.
.........the front/forward pocket can now flip downwards (like the rear one does)where you can now access the hinge screws for complete removal if you need to.
Thanks ZooKeeper,
Seems a little lubrication solved the window issue once i got the pocket off.
Thanks again:)
