10 Attachment(s)
6 and 7 inch Steelies F/S
This is a set of 4 15x6" and 2 15x7" steelies. All of these have been stripped and professionally powdercoated silver and then had a matte clear powdercoat on top. These were powdercoated by Forgeline. I must say the finish is exactly what I was looking for! Not too shiny but not too dull. Anyway, I have decided to go with deep 6 and 7r's so these need to go. None of these have had a tire mounted since they were refinished.
The 15x6 (qty 4) have a center stamping date of 3-76. They were apparently made a long time ago and have a one piece 6" outer rim on them. These all measure 105mm from the mounting surface of the wheel to the back outside of the rim. These should be correct for all early cars. Asking $650 plus shipment.
The 15x7 (qty 2) were made when someone added the material to the outside of the rim. These were just used for AutoX by and guy when I bought them. They still had all of the weld showing and I ground as much as possible off and made them look as good as possible. You can still see some weld that I couldnt get to. These measure 125mm from the mounting surface of the wheel to the back outside of the rim. I compared this measurement with a pair of 7r's (with the 1/2 spacer and it looks like these will stick out about 1/2 more than the 7r's. This means that on a very low car with certain tires they may rub. That is all I really know. I dont have rear control arms on my car so I cant do a test fit. They would probably ok on a car that had a normal ride height but I cant say for certain. Asking $200 plus shipment.
I can take additional pictures or measurements as needed! Thanks, Mark
