2 Attachment(s)
Porsche spec foglight questions...
Bought a set of the new Hella "tractor lights" to use as fogs on my 911T. I want to "convert" mine to the proper Porsche spec. I have read through all of the posts I could find on foglights but want to make sure I have the details correct:
The main differences between the current lights and the ones originally supplied are the lense, larger hole through the base for wires, and a thinner lense clip with slotted screw. The new ones also lack the terminal for the ground. I have the proper TN4 lenses, larger grommet, correct clip/screw, and terminal scavenged from dead 914 fogs. A few questions:
-With the black cutout grills, where does the wiring run through the grill? Is it through the same cutout that the light goes through or the next space up?
-Is this light supposed to have the 5th rivet for the ground terminal or is that just for the driving lights? If not, then is the ground terminal riveted to the base like the 914 fogs? (See below)
Thanks much,
Steve
