I'm selling a set of H1 headlights. They're in good shape, all of the adjusters work, and they have a set of new lenses and internal gaskets. Trim rings are included, if needed. $800, plus shipping. Pictures are below.
Jeff
Jeff
Okay, here's the first group of pictures. Close-up photos will follow shortly. The one on the left was originally painted black on the outer rim, so the
plating on it has a duller appearance to the one on the right. It has also had a couple small repairs, where you can see the brass color. If you wanted to use
the light without the painted trim rings, you would want to have the plating redone on the left one. If you use the painted trim rings, you can use it as it
is. The trim rings should be repainted, as they have numerous small chips in the paint. If you don't want the trim rings, I'll sell those separately.
The lenses and gaskets on both lights are new.
Jeff
More photos:
I've had several inquiries in regards to the painted trim rings and screws. In short, those will be sold with the lights, unless the buyer doesn't want them. In that case, I'll sell them separately, but only after the lights have been sold.
I'd like to sell the lights first, so make me an offer.
Jeff
The lights have been sold. For those of you that inquired about the trim rings and screws, they were sold with the lights.
Jeff
