I am behind on three engine builds. I have a 65 case 903900 type 901-01 number 3821 that has been modified for a short stroke large bore MFI race engine...(larger spigots, MFI platform etc). I am not going to build this anytime soon. I have accumulated most of the parts to build the engine...S-RS MFI pump, cams, TBs and stacks, 66mm crank and rods etc. Wondering given the early case if I am better off to use a later less valuable "more robust" case, and try to find someone needing an early case to match a vin...to help them out. This is not meant to be a price check. Thoughts?
Speedo
