Radio question
My 67S came with Blaupunkt Radio 'Frankfurt', (737.581), Loudspeaker, Antenna. What is 737.581 and does antenna mean electric antenna? With factory radio would it not be assumed there was an antenna an therefore not noted on the kardex unless it was electric? Any thoughts? TIA SS
I don't think anything was assumed, you could get the suppression set-up and antenna, but without the radio if so ordered. When the antenna was electric I'm sure that was specified. If your antenna is on the left fender it was a manual, the electric had to be mounted on the right fender.
