2 Attachment(s)
Zeniths and Marelli: Opinions on Induction/Ignition for a 2.2T
I've got a '71 911T thats still running it's stock Zeniths and Marelli distributor and I wanted some thoughts from those that have experience or insight with this setup.
Right now the car is still running it's stock CDI ignition which I intend to keep but I want to know if it's worth it to rebuild the Zeniths (which need to be rebuilt) or just by a set of Webers. I've heard all sorts of stories related to the impossibility of tuning Zeniths (even after being rebuilt) so they run correctly/well and I'm not really sure if I should spend the money to rebuild them and try and set them up or spend the money elsewhere. At this point the car pops and sputters from both the carbs and the exhaust depending on load and RPM so I know there are issues that need to be addressed. Any thought from the experts? I'm not really sure which way I should go, spend the money rebuilding the Zeniths or look for a set of good, operable Webers.
Secondly, I've still got my original Marelli distributor and given that parts are now being produced should I just keep it and have it rebuilt or look to by a Bosch to replace it? If Bosch is the answer, which Bosch unit do I need as a replacement?
My car is used as a driver and reliabilty and ease of maintainence are my primary concerns (with budget also being a consideration) so I though I'd look for some advice before taking a blind leap in one direction or the other.
Thanks in advance,
Stretch
Attachment 232694Attachment 232695
