These 2 stickers came on a 1973.5 911T. Has anyone ever seen them before? Any ideas to what they were? I have attached a pic and look forward to hearing any ideas.
If it has shielded/grounded plug wires perhaps that was the campaign? Porsche's "solution" to blowed up airboxes.
It didn't work.
I think that may have been the fuel line reroute recall that burned a few in the beginning. There were other "Campaign Codes" (you might call it a recall that didn't go far enough) but the fuel line caught the most attention along with the shielded wires fiasco as Frank mentioned.
What ever you do, don't remove it or the mattress tag police will hunt you down...:)
H
Three recalls: (From http://www-odi.nhtsa.dot.gov/owners/SearchVehicles)
RECALLS: Displaying 1 - 3 out of 3http://www-odi.nhtsa.dot.gov/owners/images/minus.png RECALL Subject : FUEL:FUEL LINES FITTINGS AND PUMP
Report Receipt Date: JUL 08, 1974
NHTSA Campaign Number: 74V109000
Component(s): FUEL SYSTEM, GASOLINE
Manufacturer: PORSCHE CARS N.A. INC.
SUMMARY:
CONSEQUENCE:
REMEDY:
NOTES:
PORSCHE CAMPAIGN NO N/A. EQUIPPED WITH CIS. POSSIBILITY THAT THE FUEL HOSEINNER DIAMETER EXCEEDS SPECIFICATIONS. THIS CONDITION PREVENTS PROPERCONNECTIONS, RESULTING IN FUEL LEAKS IN THE ENGINE COMPARTMENT OR UNDERNEATHTHE VEHICLE. ALSO, THE O-RING GASKET AT THE REAR OF THE COLD START VALVE MAYHAVE BEEN IMPROPERLY INSTALLED AND COULD PERMIT GASOLINE LEAKAGE. IF THESECONDITIONS EXISTS IT COULD RESULT IN A FIRE HAZARD. (CORRECT INSPECTING ANDREPLACING HOSES AND O-RING WHERE NECESSARY).
<input type="checkbox" class="pChk" style="margin: 0.4em 0.3em; padding: 0px; vertical-align: middle; border-width: 0px; "><label style="display: inline; font-weight: bold; margin: 0px; padding: 0px; ">Request Research</label>
http://www-odi.nhtsa.dot.gov/owners/images/minus.png RECALL Subject : LIGHTING:SWITCH:MULTI-FUNCTION SWITCH:TURN SIGNAL
Report Receipt Date: SEP 19, 1973
NHTSA Campaign Number: 73V191000
Component(s): EXTERIOR LIGHTING
SUMMARY:
CONSEQUENCE:
REMEDY:
NOTES:
PORSHE CAMPAIGN NO CN. POSSIBILITY THAT THE ELECTRICAL CONTACT POINTS INSIDETHE INTEGRAL TURN SIGNAL AND DIMMER SWITCH WERE IMPROPERLY MANUFACTURED. IFTHIS CONDITION EXISTS AND THE HEADLIGHTS ARE TURNED ON EITHER HIGH OR LOW BEAMSAND THE TURN SIGNALS ARE OPERATED, THE HEADLIGHTS WILL GO OFF WHEN THE WHEELSRETURN TO THE STRAIGHT AHEAD POSITION AND THE TURN SIGNAL CANCELS. (CORRECT BYINSPECTING AND REPLACING WITH NEW DESIGNED SWITCH WHERE NECESSARY).
Report Receipt Date: AUG 14, 1973
NHTSA Campaign Number: 73V168000
SUMMARY:
CONSEQUENCE:
REMEDY:
NOTES:
PORSCHE CAMPAIGN NO T 44/73 PA. COUPE AND TARGA. POSSIBILITY THAT THEDIAPHRAGM INSIDE THE WARM-UP REGULATOR MAY CORRODE AND LEAK. ALSO, THE LOWERHOSE CLAMP ON THE FUEL LINE CONNECTING THE FUEL ACCUMULATOR AND FUEL FILTER MAYHAVE BEEN IMPROPERLY INSTALLED. IF THESE CONDITIONS EXISTS IT IS POSSIBLE FORFUEL TO LEAK AND CAUSE A FIRE IN THE ENGINE COMPARTMENT. (CORRECT BYINSPECTING AND REPLACING HOSE,CLAMP AND WARM-UP REGULATOR WHERE NECESSARY).
Ask and ye shall receive...
Wow.. Thanks again 911sregistry..
Is there anyway, I could find out if my 1973.5 had this done? Does Porsche keep recall information by VIN and prove to NITSA that the car had it done?
If it wasn't done it would be burned up by now.
H
