5 Attachment(s)
FS: Headlight glass, rings, screws
I sourced some new glass from Europe to offer with the headlight rings I have. Everything that I have seen offered now has the script on the inside.
Clear Hella SB19-SB20-SB21, $90 per pair. Stamped Made in Germany, have all inscriptions they are supposed to.
Clear Bosch Assymetrical for Euro lights, 65-67 style with no shelf top, these are the 4487 units. All correct inscriptions. $170 per pair.
These look particularly good on the later cars not only 68 to 73, but also SC's, Carreras and 964's as they change the front end look of the car and are directly interchangeable into the "standard" H4 headlight assemblies.
(note that I had these in yellow but they are sold out, should have them back in stock soon at $190 per pair).
I've been also offered the solid yellow (not painted yellow) H-1 AND H-4 headlight glass, but I know this has been around for a while and I'm not sure if this is still desireable. These would be $195 per pair (plus shipping of course). Pictured here as well below. I have a very limited stock on these but I can get more if there is a need.
Thanks!
Eric
autoforeign@gmail.com
