Picture of window washer pump metal sheet and location
During welding the metal sheet on which the window washer pump is bolted on, got lost. We can probably fabricate a new one ourselfs but a picture of the metal sheet itself and the exact location would definately help. Would anynre be willing to make a picture?
Mine is a 68 and it was located next to the washer reservoir.
Many thanks!
Martijn
1 Attachment(s)
1968 round tank with bottom flange
Martijn the tanks changed from 1966/67 to the year 1968.
1967 was the rectangle tank with the neck/cap behind the lid closure panel and next to the battery.
1968 the neck/cap are in a round hole through the lid closure panel. This was a rounder shaped tank with a flange on the bottom. That flange is held in place by a simple stand up bracket that I have illustrated below (the shape is about what it looked like - it is drawn from memory). The washer pump (EDIT) is in the same pace as the 1967 bracket welded to the floor - the tank changed again in 1969 (EDIT) where is slid onto the side of the plastic tank and held in place by the nesting shape of the plastic.
I hope someone posts a photo of the tank and its mount.
2 Attachment(s)
1968 round tank 1969 tank round with pump mount
Here are two photos showing the tank shape and the distinction of the 1968 /1969: 1968 no tank bracket - 1969 bracket cast into the plastic.
Photos are borrowed from others.
