Is there any Porsche documentation that states that an M471 vehicle must be used to create an M491? Information that says this exactly. From my point of view, a 471 vehicle for the circuit is not the same as one for rally, so it seems strange to me to add the same modifications for either. From my perspective, vehicles that were for the circuit and (if it's true, which I don't know) were based on an M471, would not have been raised in height, for example, for rally performance. From what I understand from the comments, the same M471 that was used in rallies was used in circuits by adding the 2.5L engine (M491) with the same rally modifications that the M491 would include? For me, it needs a closer look because I don't quite see the use of M471 (as such) in circuits along with M491.
I think the Z program vehicles from 1972 fit better on a list of M471 chassis.
"Is there any Porsche documentation that states that an M471 vehicle must be used to create an M491? Information that says this exactly"
I think the answer to this is in the 1970 document where they mention that there is a 911 S/T prepared in the factory AND THAT IN ADDITION it could be prepared for... I think that when it says "in addition" it is as you indicate, an over-equipment on a 911 S/T, I suppose it will be related to M471 although it is not entirely clear to me that when naming the S/T in that circular, it is being named "m471"
*If it is clear to me, looking at the title
SportausFurung
Attachment 622392
Even so... I still wonder if there are M491 vehicles with the inscription T on their sheet (I think not) except for the Z-programm 471+491. So from my point of view I still think that if that annotation does not exist, perhaps this list of
21 - Z-programm should be called something else.
Regarding the car you mention, I seemed to understand that for 1970 m471 meant something totally different from a sports package?
I believe that in 1972 compared to 1970, m471 and m491 definitely existed. Hence the document where it only mentions those two packages separately, perhaps in 1970 the s/T could be equipped for the circuit but I think that in 1972 where the sports equipment 471 and the racing equipment 491 are mentioned it should not include 471, and those that include it are marked with program Z, that's what that program was made for, I understand that to mix the two characteristics something that is not done according to my thinking in the famous client/career
Is the dead pedal on the 550 spot-welded or seam-welded? From my understanding, if the vehicle is as I believe (taken from the assembly line), it should be seam-welded rather than spot-welded. Does anyone have a detailed photo of this?
https://www.porsche-st.com/
A really great video:)
Attachment 622459
