Weather forecast? Check (no rain, but will be silly hot by afternoon).
Full tank? Check.
Water bottle? Check.
Tire Pressure? Oil level? Check. Check.
Food? Nahh. I'll be home in time for lunch.
Driving buddy? Well, merbesfield said something about having to work and no front cooler yet on his '73S. So solo it is...
What better way to spend a day off of work?
Well, if you live in Atlanta and it's August and you like to drive, you get up early... like before sunrise early. Why? To beat the heat and the rush hour traffic. And you head north into the Appalachians to stay cool and exercise the ride on roads that cater to the car's purpose built nature.
Attachment 222102
Once out of the foothills of the northern suburbs of Atlanta, the route takes you onto a low ridge, eventually making its way up to the Eastern Continental Divide at Neels Gap.
At 3109 feet above sea level, Neels Gap is the first worthwhile rest stop at about an hour and a half into the trip. The Appalachian Trail (AT) comes through this gap and passes underneath a roof of the outdoor gear store/hostel--this is the only time the trail goes through a manmade structure on its entire 2200 odd mile length. I've hiked the 80 or so miles in GA and parts of it all the way up to Maine. But I digress.
Attachment 222103
Since it's early and the sun is still relatively low, you are hitting all the high elevation gaps before the sun can even touch the roadway down in the narrow valleys.
Attachment 222104
The overall route crisscrosses the AT a few times, climbing from ~1000' down in Atlanta up to just under 4700' at the Brasstown Bald parking lot. This is two hours into the trip.
Attachment 222105
From the highest point in Georgia (4784'), it's back down the super steep grade of the Bald spur road and over to the Richard B Russell Scenic Highway and a tasty scenic overlook at ~3600 feet. It's about 9:30am now. This expansive view was uninterrupted in the solitude and quiet, as I had the roads to myself!
Attachment 222106
continued in next post...
