Thanks Henk! Can you find the casting dates for the case, and the pairing # on the top please.
Heres a mag case engine I have, sorry for semi good Iphone shots
3380373
901/17
15815
624 parting line numbers
12/68 casting date
This is the motor in my US 1968 911L.
68 911T
901/03
2080096
9827
I just picked this motor up from Craigslist locally (Seattle) today. It has:
Serial #900490
Type #901/01
Production #390
Case half #553
I can't find the casting date. Where is that located?
This should help, on the other side of the case it is in a similar position.
-Allen-
Allen,
That is where I was looking and it is not there. Was this date cast into the case or stamped. If it is a stamp, I think they moght have missed it on mine.
Scroll up a page back and you will see the location for the other side. The date "stamp" was put into the sand mold before the case was cast I believe.
It should be there unless the very early engines had something different but I don't think so.
-Allen-
Use a very strong light and clean with a toothbrush with solvent. it is only about 1/2" around. Look here - and on the mirrored other half.
