As they say, pics or it didn't happen...
Attachment 284246
Attachment 284248
Attachment 284249
Attachment 284246
Attachment 284248
Attachment 284249
Super cool Marco......... :)
Love the steering correction in the second pic........ ;)
Nice photos Tony!
very meaty.
Drove it, like I do every day. :)
http://i.imgur.com/v572r0s.jpg
Now if this was Instagram I would #nofilter. 'Period correct' look purely on account of #poorlighting and #crapiphonecamera
I need to give HUGE KUDOS to a very highly recommended shop "Pacific Power Motorsports" in Walnut Creek California who, went WAY WAY out of there scope of work to get my car right. I am glad they had the time, energy, know how and space to work on my car correctly. With now.. any hope, all ecu and pivot bolt problems GONE.
New Throw out bearing guide tube for 901 Transmission
New Front Brake lines with new tees to master cylinder
New Brake fluid - high temp brake fluid, bled and fill
New Tranny fluid - Swepco 80/90 Gear Lube
New Brad Penn 20W50 Motor Oil and Filter
New ball stud modified with washers
New Sachs clutch disk
New muffler gaskets
Fixed leaking right rear fuel line from tee fittings to right fuel rail
ps.. we dealt with the ecu issue a couple of visits earlier.
If you have any issues with your 911.. and sometimes it just takes a smart person... I super highly recommend Eric. I am telling you, this guy bent over backwards for this car. Thanks a real lot. You can reach him at 2149 North Broadway, Walnut Creek, 1-925-937-2277
got the oil lines ready to accept the filter housing. I forgot to hook the speedo cable up so I had to drop the trans a little to do that. I had forgotten to put the oil line on the motor, so I had to pull the exhaust and put it on. Thermostat machining is being done.
Things are feeling very close. I'm nervous.
I'm moving.... likely to a smaller garage. I'm going to miss this place. Oh, dont freak out. the jack is just holding up the oil lines ;)
http://farm4.staticflickr.com/3771/1...cbf6837d_b.jpg
