heater and positioning in car
I have seen photos of a1970's werks ST before restoration with a fuel pump for a heater attached up under the scuttle (almost under the windscreen) on the Right hand side.
I am confident that it was original to the car and was in the original position for that car.
however I have never seen one in situ before and would be interested to know if this was the standard positioning on all cars or only on this werks ST
6 Attachment(s)
can anyone identify these 3 switches?
This is a picture from an early 1970's Werks ST rally car showing the dash.
There are three switches that I would like help in identifying.
they are the red and yellow/green ones to the right of the heater / air controls and the one without a knob on it further to the right.
this car had 4 auxiliary lights, a petrol heating system, full rally Halda or twinmaster etc,
I have attached a closeup of the switches as well in higher resolution where you can see the third switch looks like it is more like a rheostat or something that twists (and maybe should have something on it as a knob.)
however a photo of the interior of the Larousse 1972ST for the Monte, also attached shows a similar setup (highlighted in red). Again the third switch does not appear to have a knob on it and seems the same as the one in my picture. Maybe it is an adjustment for the brightness of the map light above it - but that is a wild guess on my part.
and , no , I can't follow the wiring to see where they go to - it is all disconnected
I dont recall seeing anything similar before -- anyone??
6 Attachment(s)
seat police please examine
These are what appears to be a matched set of seats from a Werks ST rallye car.
One looks identical to the Scheel that Raj posted the adverts for (Rallye 400) in post #203 , and it does look different to the one in his car (apart from being dirtier)
The other, navigators, seat I am not sure about. I does look a little like an early Recaro but I am no expert in this area.
neither have headrests but there is provision for them.
the seat base of the large seat seems to be all aluminum and tips the seat forwards to gain access to the rear.
Questions:
1 is my identification of the large seat correct?
2 did it come with a tilting base?
3 is it likely to be aluminum as standard or not?
4 can anyone identify the other seat?
5 I have never seen an interior photo of a competition car of that era that did have headrests, would they have been used or not?
