907565
4430
901/05
VIN 304353
http://carparcusa.com/detail.php?id=75#top
Henk provided me w/ type and VIN number
Richard
4430
901/05
VIN 304353
Richard
As seen on ebay.de
Motornr. *900723*
type 901.01
seq. number 623
No. on case halves: 775
Date stamp 64
http://cgi.ebay.de/Porsche-911-Motor...t_30347wt_1167
Richard
Today I came across the following car:
VIN 304791
engine 907956
901/05
4824
RIchard
Thanks Richard, you have been busy!
There are three missing builds between 4784 and 4824 that I suspect are 901/20 engines, and your data points are helping.
What else can you tell me about 304791?
I just added a bunch, including one that is quite interesting: build 3419. This advances the series of in sync serial numbers by a few hundred, and reduces the gap within which the first 901/20 engine is built to less than 100. Thanks to all the eagle eyes out there helping out.
I saw this one:
901541
1441
901/01
Richard
http://cgi.ebay.com/ebaymotors/Early...#ht_500wt_1182
I just purchased the complete and unmolested engine 900348:
900348
901/01
248
Another one that can be added to the list!
See picture.
Thanks, Henk Baars
Thanks Henk, if you get the chance while restoring it, please find the pairing number on the top, and the casting date on the end.
Just noticed the KD after the serial #. I have not seen that before. Any suggestions?
Thanks Richard, you are always helpful.
Dave
The engine from my 67S SWT is 9611363 with build number 7738. I could not see the case matching numbers were it is currently sitting . I will get it for you sometime later.
Tom
Dave
I have a 65 engine on the shelf
901761 with build number 1661 and case match number 372
Tom
