Kris, those must be late '72 911's! Notice one of the Basketball referee's (over your right shoulder) from the '72 Olympics demoted to now cleaning Porsche engine bay's.
Attachment 305480
Removed the 6 X 15 Fuchs and installed 5 1/2 X 15 Steel Wheels with new Verdestein 185/ 70 tires. Next project will be to replace the steelies with the alloy versions.
There is no better way to pick up a poutine...Attachment 305519
removed the pedal cluster....berk ! The brake system has been modified to accomodate power brakes :) Will get the original back.
Attachment 305523
Attachment 305526
A first for me: put the 72 hot rod on a chassis dyno.
what motor set up is that?
Took the 1970 911E racecar out to Willow with the POC for my first Racer's Clinic. During Friday practice the T/O bearing started to sing ... by the end of the day the bearing was howling. I spoke to my crew chief, Dad, and his advice was pretty basic, "Drive it 'til it stops."
So I did.
I gave the car no quarter; four run sessions on Saturday and four run sessions on Sunday with multiple starts each day and a final race on Sunday. The car never missed a beat despite the awful screeching and grinding sounds every time I pressed the clutch. :D
Then, on Sunday night as I was loading the car onto the trailer...
Ouch! Those trailer loadings are hard on a car. You should know better :D
