on paper yes. But from previous year the 2L 901 had always had the measured of the TR6, and now you don't have to worry about those pesky avgas MGs.
John, sorry for going off topic, blame RC.
I don't mind drifting off ;)
Does anyone have a sound factory/oem Left/passenger side exhaust heater? It can have rusty heaterboxes... This may be a good short term solution.
I have one side under a pile of stuff , but not sure which one. Will let you know once I have checked - might only be on the weekend.
Rob
Rob, much appreciated.
It seems the left one rusts out before the right one for whatever reason... I've found several right sides, but no lefts!
Attachment 237503
Managed to find it.
Rob
Brilliant Rob!
PM me and let me know what you need for it (or pm me your number and I'll give you a call).
Cheers
John I have a pair of the replacement sections that go from the muffler flange up to the weld point where they enter the H/E tin work.
The sections just basically copy the existing 3 into 1 tubes with extra material at either end to allow you to trim them before welding. I can put up a pic later.
Attachment 237746
Photo attached
