Originally Posted by
304065
Uhh, that is exactly the opposite of correct.
When you add any lubricant you reduce the surface friction, which allows you to put more preload in the fastener (stretch) before the wrench clicks. Think about it like this-- which would click sooner, a torque wrench on a lubed bolt/nut or a rusty one? Of course the rusty one has more resistance and will click sooner with the bolt elongated less.
So with lubrication. . . LESS torque than specified. For lug bolts, which are 10,9 property-class and there are FIVE of them- I would stick with 94 ft/pounds and call it cool.
